big brown horse
Hoof In Mouth
Easy Itallian Sausage
(Not too costly either, mama like!)
First off, ingredients:
1 pack of Italian sausage
1 large onion, chopped in half and then diced
3 cloves of garlic, use garlic press, if that's not available simply dice it up (or smash with a brick of granite
2 teaspoons of sage (dried)
approx. 1/4 cup olive oil
1/4 cup of butter
To start out, you want to drizzle the olive oil on the bottom of the pan, you want enough so that it's touching the entire bottom of the pan, and has a little bit of depth to it (add more oil if there is barely enough to coat the pan). Once the pan is oiled up, add the butter, and turn the burner on high. Make sure you mix the butter and oil up a bit. This part is mainly to keep the onions from burning, but it also keeps things from sticking.
Next, add the onions, garlic, and sage to the pan, and mix them up until they all settle around evenly. Put a top over the pan, and switch the heat to medium. Cook until the onions start to become soft. Mix this up every 2 minutes or so, so that the juices start to come out.
Once the onions are done, it's time to cook the sausage. Place each sausage in the pan individually, and make sure you nestle each one to the bottom of the pan, so that it gets browned. Turn the burners back to high, and cook the sausages covered for about 15-20 minutes, depending on how much oil you put in. Make sure to flip the sausages every 3/4 minutes, so both sides get nice and brown. You'll know the sausages are close to done when they become hard to the touch.
When you're done, not only will you have delicious Italian sausage, but caramelized onions to boot! Can be served on a bun, but are just as delicious by themselves. Don't you dare put any condiments on these, unless it's the aforementioned onions you just made.
Note: If you plan on making more than one pack of sausage, you don't have to double your ingredients, the onions should last through a second batch, but you will need to drizzle a little more oil, and the onions will probably be burnt at the end. For the best results, start fresh with each pack.
Now do you have a manly-man type of recipe? I'm going broke trying to feed my teen.
1/4 cup of butter
with funny pic!
