Miso (Red and Sweet miso) and Miso Soup (and other miso recipes)
big brown horse
Hoof In Mouth
Puget Sound, WA
From Wild Fermentation
Though miso is classically made with soybeans, it can be made with any legume or combination of legumes. I've made miso using chickpeas, lima beans, black turtle beans, split peas, lentils, black eyed peas, kidney beans, adzuki beans and more. The distinctive color and flavor of each bean carries over into the miso it produces. Use what is abundantly available to you, and be bold in your fermentation experimentation!
Red Miso
Time frame: 1 year or more
This miso is strong and salty, and it requires at least a full year of fermentation. It is a style traditionally known as red miso when made with soybeans, though its color can vary, especially using different beans. A shorter-term "sweet" miso recipe will follow this one.
Equipment:
Ceramic crock or food grade plastic bucket, at least one gallon/4 liter capacity
Lid that fits snugly inside (plate or hard wood disk)
Heavy weight (scrubbed and boiled rock)
Cloth or plastic (to cover the crock and keep dust and flies out)
Ingredients (for one gallon or 4 liters)
4 cups/1 liter dried beans
1 cup/250 milliliters sea salt, plus 1/4 cup/60 milliliters more for the crock
2 tablespoons/30 milliliters live unpasteurized mature miso
5 cups/1.25 liters koji (about 1 3/4 pounds/850 grams)*
Process:
1. Soak beans over night and cook until soft. Take care not to burn the beans especially if you are using soybeans, which take a long while to cook.
2. Place a colander over a pot and drain beans, saving bean cooking liquid.
3. Take 2 cups of the bean cooking liquid and dissolve 1 cup of salt in it to make a strong brine. stir until the salt is completely dissolved. Set the brine aside to cool.
4. Mash beans to desired smoothness, using whatever tools available. Leave the beans fairly chunky.
5. Check the temp of the brine. (Just stick a clean finger in and once it is comfortable it is ready.) Once it is comfortable to the touch, take about 1 cup of it and mash the mature miso into it. Then return the miso mash to the brine, add the koji. Finally , add this mix to the mashed beans and mix until the texture is uniform. If it seems thicker than miso you've had, add some more bean cooking liquid or water to desired consistency. This is your miso; the remaining steps involve packaging it for its long fermentation.
6. Salt the bottom and side surfaces of your fermenting vessel with wet fingers dipped in sea salt. The ides is to have higher salt content at the edges to protect the miso from unwanted wild organisms.
7. Pack the miso tightly into the crock, taking care to expel air pockets. Smooth the top and sprinkle a layer of salt over it. Don't be timid about salting the tp. You'll scrape away the top layer and discard when you dig out the miso.
8. Cover with a lid. A hardwood disk cut to exactly the size and shape of your crock is ideal, but I usually use the biggest plate I can find that fits inside your crock. Rest a heavy weight on the lid. (Same as sauerkraut.) Finally place the outer cover on the whole thing to keep dust and flies out. Tie or tape the cover over the crock.
9. Label clearly with indelible markers. Store in a cellar, barn, or other unheated environment
10. Wait. Try some the fall or winter after the first summer of fermentation. This is called one year miso. The years are counted as the summers, periods of most active fermentation, that have passed. Repack it carefully, salting the new top layer. Then try it a year later or even a year after that. The flavor of miso will mellow and develop over time. I tried some nine year old miso recently and it was sublime, like a well-aged wine.
11. A note on decanting: When you open a crock of miso that has been fermenting for a couple of years, the top layer may be quite ugly and off-putting. Skim it off, throw it in the compost and trust that below the surface the miso will be gorgeous and smell and taste great. I usually dig out a whole 5 gallon of miso at once. I pack the miso into throughly clean glass jars. If the tops are metal, I use a layer of wax paper between the jar and the lid, as miso causes metal to corrode. I store the jars in the basement. Since fermentation continues, the jars build up pressure, which needs to be periodically released by opening the jars. Occasionally, mold will form on the surface of a jar of miso. As with the crock, scrape it away and enjoy what remains beneath it. To avoid these inconveniences, you can store miso in the fridge.
*Koji is grain, most often rice, inoculated with spores of Aspergillus oryzae, a mold that starts the miso fermentation. Can be found @ the South River Miso Company and G.E.M. Cultures
big brown horse
Hoof In Mouth
Puget Sound, WA
Sweet Miso
Time frame: 4-8 weeks
Special Equipment:
Same as miso process described above
Ingredients (for 1 gallon/4 liters):
cup125 milliliters sea salt
10 cups/2.5 liters koji (about 3 pounds/1.5 kilograms)
Process:
Follow the steps detailed for miso, above, with the following modifications:
1. Use only cup of salt rather than a full cup, and 10 cups of koji rather than 5 cups.
2. Sweet miso does not use mature miso from an earlier batch. Mature miso contains biodiverse organisms, including acid-creating Lactobacilli. Sweet miso is sweet because it is fermented primarily with koji molds and decanted before Lactobacilli have an opportunity to proliferate.
3. There is no need to salt the crock for this short term miso.
4. Store the crock in an unobtrusive corner of your kitchen, or any other warm place where it wont be in your way. Sweet miso ferments quickly in a warm environment. Try some after a month. Decant some to eat young, store it in the refrigerator and carefully repack the crock, leveling the miso surface, and replacing the lid, weight, and outer cover.
5. Continue fermenting for another few weeks to a month. When you decant the miso, you will notice that the koji grains are still intact and crunchy. Puree the miso in a food processor with a little mater to make it into a smooth paste. Pack the miso thoroughly clean glass jars. If the tops are metal, use a layer of wax paper between the jar and the lid, as miso causes corrode. In contrast to the saltier miso that can store well at basement temps, sweet miso is best refrigerated. If mold forms on the surface of a jar of miso, scrape it away and enjoy what remains beneath it.
big brown horse
Hoof In Mouth
Puget Sound, WA
Miso Soup
When you make miso soup, miso is the last thing you add. In its simplest form, miso soup is just hot water with miso, about 1 tablespoon of miso per cup of water. Add the hot water to the miso and blend it thoroughly. Boiling miso will kill it.
On the other hand, miso soup can be as elaborate as you want. Adding seaweed is generally where I start. Seaweeds have deep, complex flavors.
