Little Butter Maid Mix Master- a combination churn and dry food mixer
liz stevens
Brookshire TX
Make Butter | Dairy | Butter Churn | Food Processor | A combination butter churn and food processor for blending of food mixes and dairy processing.
Another exclusive Amish USA made product from Cottage Craft Works! Not available anywhere else online.
Made of all USA Made Food Grade Stainless Steel!
The Little Butter Maid Mix Master is a very compact commercial grade multi-function mixer/churn. Made of heavy duty 18ga and 22ga Stainless Steel with welded (not soldered) joints.
The Little Butter Maid Mix Master is built tough for use in a commercial kitchen but sized and priced for the single family farm and home. It will provide years of practical use for making butter as well as mixing a host other dry and wet food blends.
The Little Butter Maid Mix Master holds one gallon of cream making butter in approximately 8-10 minutes by hand cranking at two cranks second, approximately 120 RPM. We also carry this same churn/mixer in an 8gal with electric motor.
Measures only 9 W X 8-1/2 D X 10-1/2 Tall, (16 wide including the crank). Inside tub measures 9 X 7. Weighs approximately 12lbs, one piece construction with removable lid. Hand crank removes, but has an Allen set screw to loosen first. Please Note: This is a very small table and counter top machine. It looks much larger in the photos.
Made of all USA Made Food Grade Stainless Steel with greaseless food grade poly bushings, it is Easy to clean and maintain. The auger bar lifts up and pulls out from the crank side.
No glass jars to break like on a traditional churn plus the tub style open top construction allows the rinsing of the butter with cold water several times from the top to remove the left over butter milk residue.
The churn is heavy enough to stay put on the counter top when cranking yet small enough to pour butter milk residue and water out as the final churning and rinsing process continues. After a few rinses the auger will be fairly clean, remove and pad butter into molds or pans.
The machine can easily be turned on end and submerged in a kitchen sink for washing with hot water and dish soap.
When spending money on food processing equipment it is always so nice to find something that can be used over and over in the kitchen for a variety of other projects.
Up until now a butter churn was a one use item. In addition mixing batches of dry mixes meant dragging out the large bowl and large spoon to hand mix these item. It is always difficult to obtain uniform mixes in this manner.
This churn/mixer is well designed and built to also mix other food products such as making cereal and granola mixes, party mixes, nut mixes, flour mixes, spice blends, vegetarian blends for meatless patties, mixing small batches of meat and cereal blends for meatloafs, sausages, and just about any other blend of dry or wet mix. Small and Light weight enough to easily pour dry mixes out one corner without scooping.
Unlike a kitchen mixer or blender, the slower rotating blades used in the Little Butter Maid Master Mixer allows mixing and blending without changing the overall food texture.
Just imagine the endless combinations of making your own seasoning and baking mixes to store ahead of time for quick meal preparation. Pancake mixes, baking mixes, taco seasoning, rib and meat rubs, just to name a few.
Sorry, The Little Butter Maid Master Mixer is not designed for bread dough or other thick and sticky food mixing.
