ThrottleJockey
- Apr 28, 2012
I have started a new project to try to get a bit more efficiency from our simple barrel stove. I have welded a barrel lid from a 55 gallon barrel to the top of a 30 gallon barrel and cut out an opening. I will put the 30 gallon drum inside the 55 gallon drum and pipe the stack through to the chimney. This will leave me with the 30 gallon drum as a firebox and the 55 gallon barrel will become a heat exchanger with a blower on the back and a vent on the front. I expect to get more heat and burn less wood at the same time with this setup when I finish it. Here are a few pics of what I've done so far. I'm noticing that the 30 gallon drum has thinner walls and is tough to weld with my el cheapo 2 temp welder, I may have to find a water heater tank to use instead for fear that this barrel will burn through too quickly when it is put into service.
Here is a view of my crappy weld...needs some work still!
Here is a view with my current stove.
I'll post more as the project progresses!
