- Thread starter
- #2,581
keljonma
Epicurean Goddess
Yes, but that isn't happening just this second......Quail_Antwerp said:um yea, I'm pretty much confused by all that now - you should so be living next door lolkeljonma said:QA, if you find that the reason for the burr comb on the inner cover is that the bottom deep hive body is full already - do you have frames ready to go for the top deep hive body?
At worst, I think you could use one of the old frames I left you that came with that white hive body. With help, you could attach that comb from the inner cover to a frame. Then put the rest of the frames with foundation in with it.
If the bottom deep isn't filled and they are just ignoring those frames, you could try putting the burr comb into it. Remove one of the frames from the newer hive body. Attach the burr comb to one of the older frames, and stick the frame with the burr comb attached into the newer hive body. Put it near the center of the hive body.
But your beek help that is coming should understand what I said.
Carefully scrape the burr comb off the inner cover with the flat end of your hive tool. With the wire I left you, you may be able to attach the burr comb to an empty brown frame (came with the white hive body and was in the large black plastic bag I left).
Then put that frame into the center of a hive body. Use the newer hive body (parafin coated) if it is not full yet. Use the older (white) hive body if the newer one is already full.
Either way, the bees will be able to continue to build on that comb and if you contain it to a frame, will be useable from a human's perspective.
